So we figured out the regular fogs, corners, and heads. But what do the lights under the high beams do? They have regular bulbs like markers, but we can't find any configuration to turn them on. Bottom row, closest to grille.
Then I'm guessing the bulbs are burned out. They have regular bulbs like turn signal bulbs, and never turned on.DRL's
:thumb:
Alright then. So in gear in daylight. I'll have to check on that then.The only time they turn on is if the ambient light sensor see's daylight and the shifter is out of park with the parking brake off.
I can almost promise you one will be burnt out though. It's a GM thing :rofl:
