Help: lift pump goin bad again
fastgreek
238
Macungie, Pa
so far i have gone thru 2 ppe lift pumps in 6 months.this is not normal.The wiring is correct and the pump is installed correct.I don't know if the cold weather is ruining these or what.Anyone have any suggestions.thanks:mad:
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
The only time I ruined my lift pump was when my truck gelled up. I had to let the truck run for awhile with 911 and forgot to bypass my pump and it burned up to the point it wouldn't move enough fuel to fuel a lawn mover.
NWTDIESEL
On a Time Out
May 8, 2008
1,405
ATS Extreme trans
I went thru 2 on my truck in -15deg-30deg weather. I sold one to a customer in AZ and his went out after two months. He is working with Dan to get it replaced........
WICKED DIESELS
you need more fuel
Until the actual manufacture Essex, implements an induction hardened shaft for the motor, the seals will continue to eat into the shaft, filling the motor with fuel and killing the bearings, brushes and armature. I have talked to them numerous times at Essex over the issues, as we used them in another form a while back. If you need a replacement seal use National 350435, the one we came up with when the supplied Viton seal failed. All the PPE pumps use this seal, which we discovered and informed Essesx of.
beach_33
704
des moines, IA
i would say that is what happened to mine. when i took it apart for inspection the inside of the moter was wet with diesel and it sure smelled like it to
fastgreek
238
Macungie, Pa
is there another lift pump that is recommended that is compared to the ppe lift pump if this goes bad on me again?And do all these lift pump go bad this fast?
mvnvltn
Part's Limit Tester
Aug 22, 2007
463
45
Sykesville, MD
That is what mine did too. No more Edelbrock/PPE lift pumps for me. :mad:
I don't think they like the cold diesel very much. They seem to do fine in warmer climates.
Alligator
Nov 9, 2006
1,919
N. Idaho
I can recommend the FASS HPFP 150 pump. I have been running it for 3 years on 2 different trucks. It hasn't let me down once. It cost about twice as much as a PPE pump, but it has a lifetime warranty on it and a proven track record in the industry.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
That's one thing I didn't test when I started using the Edelbrock pump, cold weather. After going through a Carter or two, and a Holley, I've been using the 1792 ever since and haven't had a failure on 3 trucks.
I started running these back in 2005, when Carter, Holley, and FASS were the options.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Anything about what we talked about during sema lift pump wise?
