I'm considering several options for adding a fuel pump, I've been read quite a bit on fuelab lift pumps as well as the airdog 2.
I want the flow-thru design incase it fails I don't want to be stranded.
I have a few different ideas. I was considering velocity fuel system 100 with fuelab pump, then I would run a nictane adaptor on the stock fuel filter location to get down to 2micron filtering.
Or I was considering running the airdog 2 with their filters adding the cat filter adaptor anyways on the stock location, or is this overkill?
My last option is to run a custom cat filter setup with whatever pump I decided to add in, only problem with this is I wouldn't have any idea how to set it up myself.
Any advice is greatly appreciated.
Thanks in advance
Thanks in advance
