LLY: License plate lights out
Drrrty
Dec 26, 2015
90
Hey guys I recently installed a roll pan and wired up the license plate light that came with the pan. Light worked. Then I removed the pan to do some final adjustments and remounted it. Forgot to re wire the license plate light. When I noticed I didn't have a light I looked under and re wired them quickly in the parking lot. ( did not have tape so I kept them spaced apart with a zip tie). Anyways I got home and noticed the light was out again. I looked under and a wire came loose. Re wired it and now the light doesn't come on. All other lights work and I checked fuses and no luck fixing the issue. Thought the bulb burned out so I put another new bulb in the factory plug and still no luck. Any ideas on where to check?
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Ohm across fuses. If not that then ohm from plug to ground. See if you have continuity throught the curcuit... if you dont know how to use a meter then test light that bizzzsnatch.
Drrrty
Dec 26, 2015
90
Thing is it was just working I guess when it became unplugged the open wire must have hit the roll pan and grounded out. I've checked all my fuses they all look good.
