Leveling kit pulling?
KidwickedLMM
Jun 12, 2011
70
I see a lot of guys pulling the dmaxs with leveling kits or with there tor bars turned way up. How are they doing this without spitting CVs out and or getting bad wheel hop? I've had no luck at all pulling without my tor bars turned all the way down. I want to level my truck so I can run bigger tires, but I still wanna be able to pull some this summer. Anyone have any luck pulling with a leveling kit?
03_DMAX
Aug 15, 2010
124
Youll never be able to pull with a leveling kit or your bars turned up. You will start breaking lots of things. Just lower your bars at the pull
KidwickedLMM
Jun 12, 2011
70
That's what Ive been doing, but the leveling kit I was planning on getting uses the bigger keys and you can't turn em down very far
AubleAK
Aug 5, 2011
781
30
Glennallen, AK
id stay away from leveling kits if it were me. i have one (coming off when i find the motivation) and in 4wd it walks all over the road. pulling a heavy trailer up here in alaska with the icy roads its all over the place when pulling hills.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Why not just crank the factory keys all the way up instead of wasting time and money on keys? Then you can still lower it all the way at the pulls.
RedHotGMC
stock
Jan 16, 2012
339
Northern Utah
Except if his factory keys wont go high enough then he would need keys. I think thats why he was thinking about using keys in the first place.
joechevy
Nov 29, 2011
I'v been pulling with the leveling kit combined with the skyjacker 3" lift with 315's under her no problems yet with breaking anything. I'v also been told that i cant pull in 4high but its never failed me yet. I guess if it does then its time for a solid axel swap...
bubba2400
Jul 19, 2009
199
Union Grove, WI
Front suspension stops is what you may be seeing in some of the pulling trucks. Then you could turn the bars up to clear the tires on the street and still pull the truck without tearing up the fenders too bad.
