I got the idea when I was at a local marine supply store and seen that they had water proof LED lights. So I thought about running them under the bed rail to help see at night since my cargo light is black out now. It is not 100% complete, I have to silicone the wire into the bed corner and then it will be complete.
I drilled a hole next to the open hole, I use that as a tie down spot, the wire is ran at the front of the bed through the rail. Then connected them together and ran the wire right with a factory wire loom on the frame.
Let me know what you guys think.
