Leaking trans
skidoosleds3
160
New Jersey
So what would make a little fluid come out from the breather. What caught my attention was the trans was a little warmer then normal. Normally its around 150 it was up around 200. I checked the fluid and it was at the proper Level. Is it anything to worry about? Thanks
15,681
Fluid level at 175F should not be over the half way mark on the upper hot grid. If it is, the proper level will fix itself after a few blow offs. Won't hurt it.
