So i did a internal and external filter change on my Lb7 today and noticed that there is a small crack on the rear housing of the trans where the t-case bolts up. It lets out quite a bit of fluid when running also there is fluid coming from on top of the trans towards the front. I'm thinking that might be the vent on top but it only leaks when its running and does not have too much fluid. The other day i pulled from a stop sign normally and had no response but it reved up and it said shift range prohibited or something cant remember correctly. after it did that it slammed into gear and got stuck in second and wouldnt shift and could not shift manually. i added some fluid and turned it off and it started driving normally again. any idea on that? Sorry for the long post just concerned about it going out on me.
