Leaf pack help
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
hey guys...im putting caltracs in currently and ive got both leaf packs pulled. im removing leafs and going with an airbag setup....this is probably a dumb question but im no mechanic. well i got the center bolt out (it was a PITA) that took care of the overload and now im not sure what the "correct" way to separate the other leafs is...do i just find a way to pry apart those clamp things or is there another way?
thanks
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I just bend them open..
X2 just bend the clamps open , I kept the bottom leaf in my pack always to retain the clamps , pulled the leafs out and re-bent the clamps back in place . you can buy a new center bolt or if you have a "die" you can just thread it down further , i did the later .
Oct 16, 2008
948
12
Idaho
Kinda what I was thinkin. Sounds like I'm gonna have to get caltracs before I pull some leafs. Thanks Trent :thumb:
Edit: Do you remember the difference in ride height and/or quality between running 2 leafs or 3 leafs? I though I remember you mentioning it in a thread awhile back. Had trouble finding it though.
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
I was just gonna use washers on that. Think that would be a problem? Also Trent was there enough useable thread on your ubolts? I haven't got that far but it's lookin mighty sketchy right about now
Builtlngbd
Aug 24, 2009
392
lol i used to big nuts that slid over the ubolt threads as spacers...worked great (they wer grade 8 of course) :D
TrentNell
Jul 7, 2008
7,543
slc tuah
Thanks guys. If I remember correctly trent said leaving only 2 leafs is about a 4 inch drop which is what i'm goin for:hug:
here is a pic of the ride height with only 2 leafs ( fairly light truck too ), stock shackles , and 30" tall tires , the front is just t-bar bolts removed stock keys .
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
Great thread I just subscribed to it. I'm kinda worried now the last thing I want is worse performance then my clamps. Oh well time will tell I suppose just need to wait another month for the track to open up.
Btw. My buddy Chris (dmaxchris) manages consistent 1.6 60's on just clamps and drop shackles. While I currently can't muster better then a mid 1.8 I do have junk shocks at the moment though
