LBZ's check your Hot side IC tube
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Check the hot side tube to the IC and see if it is wearing through the battery cables. Mine was about 1/2 way through the +/- cable covers with only 40K mi. The front exhaust manifold stud was also working it's way through the tube. I removed the tube to make a 3" tube, since I have blown the stock unit off three times, and damaged it.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
:eek: I think mine are OK though. Robert just checked everything on Wendy before the sledpull.
1,866
So you LBZ guys have the same issues we LB7 guys have with the IC tubes rubbing through? It does get tight down there.
Better have the LLY guys check their IC tubes while we're at it.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Cold side on dales Lbz almost rubbed through his brake line :eek:
it was actually the clamp and the way it was installed but something to look out for
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Problem solved! I finished up the 3" hot side. I've got plenty of space now, and was able to ditch a few bends. Im not sure if I want to polish it, or leave the welds as is. I would like to thank Nathan (MPI), for sending me the right direction, when I was looking for a bead roller. It was able to tackle .065 316L stainless without a problem (Bead Form HD II).
BTW- Jordan, this was done with your new welder;).
paint94979
Beer Nazi
Sep 18, 2006
11,715
That looks great Russ... I wonder how weird my truck will look with a powder coated boost tube and a SS driver side LOL
E.carter
637
42
Princeton, Iowa
Thanks for getting me out of the house at 9:30 tonight to go and check out mine with a flash light in the garage:D I didnt find any issues but I will be checking closer soon. Thanks for the info:hug:
