LBZ Turbo on LB7
bleeddiesel
Jul 13, 2012
Has anybody done this? Is it even possible? Ive read you need something from fleece to get it to work. If anybody has done this I would love to hear about it and get a list of parts that you needed to do it.
bleeddiesel
Jul 13, 2012
from what I understand performance wise none, but the sound of the LBZ turbo is awesome and I don't have the tranny to but a bigger waste gated turbo on it.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Nothing really. Better off going to a 366 or similar for the amount of changes you'll have to do to make it work.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
Pull the stock intake, turbo mouthpiece, downpipe, possibly oil drian line, and CAC pipe off a donor. Everything should bolt right on. You will pick up a little torque earlier on in the RPM range simply because the turbo will produce boost sooner, the overall power will remain the same, or close there to. If you find the right place you could probably do this for $3-400 bucks except for the controller. Cheaper than most aftermarket all-inclusive kits, but will not give you much in the power department. Lots of work for a "cool" sound. :D
