lbz to lly
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
will lly injectors swap into a lbz engine. and also what is the process to make a lly engine harness and ecm work on a lbz engine or is it not possible. can i just strip the outside and intake and make this work or are other harnesses different also.. and worst case is it difficult to swap my lly truck to a lbz???
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
You're going to have to swap to an LBZ reluctor wheel on the crank among other things. I'm just using an LBZ engine to start the build with and then I converted the harness over. I have a Corvette heads up display sitting on the dash too :D which is pretty darn sweet! The truck is a frankenstein now.
