Lbz Stock Turbo Heat Sheild Temps?
yellowchevy
1,926
82
Louisburg, KS for now
You'd have to ceramic coat it at the least, it also depends on the temp rating. If you can get it ceramic coated for a good price I would do it and probably install a turbo blanket to help keep the under hood temps down the most. If its more than you want to spend then I would just get a turbo blanket from Levi and you'll be set.
Yellowchevy
minerigger
2,660
Casper, WY
I'd honestly toss the heat shield and get a good high temp ceramic coating and then put one of levi's turbo blankets on, and if your super worried have him make you a dp blanket and get his up pipe blankets. I'm seriously debating it
yellowchevy
1,926
82
Good catch on the downpipe and up pipe blankets, I really like the ones I got from him. :thumb:
Yellowchevy
minerigger
2,660
Casper, WY
Dude levi's blankets are legit. After they get hot they are still pliable and I was looking at them earlier tonight and found a post he said he put his hand on one from a sled puller after a pass and put his hand on the blanket and it was like warm clothes out of the dryer. That right there says they work
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Did you say down pipe blanket, all snuggly and warm looking, I forgot how the OEM downpipe heat shield covers part of the passenger up pipe, still have to order one from Levi. I also had him sew a blanket, actually a sleeve for my 3" hotside pipe, sure quieted things down in the cab, little if any turbo whistle now....Turbo blanket next, maybe...
LBZ-DURAMAX
Jared
Feb 12, 2015
193
NW Ohio
Just talked to Levi and ended up with the turbo cover and up pipe socks :D ... On a side note he seems like an awesome guy to deal with and very informative/ helpful :thumb:
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
His stuff is beyond amazing. On a side note the factory heat shields are garbage and I threw all mine away long before I got one of Levi's turbo blankets.
Oct 16, 2008
948
12
Idaho
Where can we buy this stuff?
You can call the number or hit the link in my signature.
On Edit: Not sure signatures are visible on tapatalk, so here you go if it isn't. (208) 251-9141 and the link
Thanks for the nice compliments everyone. Always a good day when you hear that everyone is happy with what you're doing. :hug:
9,903
149
You won't be disappointed. It is the best way to go for insulation against heat.
I have run Levi's stuff before and it is top shelf quality. I just ordered some for my 3794 and S480.
