LBZ rail pressure sensor on LLY
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Does anyone have the appropriate scaling table/info for putting an LBZ/LMM rail pressure sensor on an LLY? I would like to log higher pressures...
I know you can rescale the sensor reading with EFILive but I cant find what to put in that table to make it read properly with an LBZ rail pressure sensor..
thanks
Ben
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Yeah I already tried that, my truck still wont read/command above 26,xxx (180mpa).... :(
Yes, B1011 is maxed out etc...
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
basically Dan at PPE said an LBZ rail pressure sensor can be used in an LLY to read higher pressures.....but the entire scale of the sensor is different from 0 to 200mpa. (ie, its not the same as the LLY sensor from 0-180, and then just adds the extra to 200mpa)
I asked several times if he had any info on rescaling it but never got an answer.
ben
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I was told it wasnt linear simon, otherwise I would have just done that (what you suggested) from the beginning.......
13,714
776
Ben, if you want, I can log my truck and find out what voltage equals what pressure.
RickDLance
1,276
14
Damn!! You guys really need to let this go, or at least keep it behind closed doors.
Ben, I got the info from Tony Burkhart last year. I'm pretty sure he got it from Dan at PPE. I'll see if I can find the paper.
CaptPhil
1,012
Delaware
I know this is old as hell, but I am wondering if you ever got this to work Ben?
I run pretty high pressure in white Devil and would like to see exactly how high it is going.
CaptPhil
1,012
Delaware
What sensor do you run? Just a normal lbz/lmm?
Pretty sure I cracked an injector body Friday night when I got out of the throttle fast due to spinning. Gotta make some high pressure system changes.
