I will be tearing down the Allison next weekend in the 2006 LBZ, crew, DRW. Service body, pickup box delete (A crew cab cab/chassis was not manufactured). I have a greater than 50% need to run a PTO driven pump, so I want to be sure the trans is ready for a PTO, whether I mount it during rebuild, or later. Driver's side mount is the only way I can see, very tight with exhaust on passenger side. Hogging out the floor and fabbing a clearance wart is not a problem.
Will this unit be equipped with PTO gear? If not, what is needed? Is there a TCM or PCM issue to be considered? Thanks.
