the truck has sdp twins on it, and the stock charger started not making any boost and all the truck does is smoke until the big charger lights. took the stock turbo off, split it apart, cleaned the unison ring and fingers(that werent stuck), put a new actuator in the turbo and new sensor on top. still getting p0045 and is still laggy. no shaft play, no oil in housing, turbo looked perfect while apart. any suggestions? and its not the tuning because it was fine for a long time. thanks
