06 lbz put a new turbo on it this weekend. 63mm with vgt. “drop in unit”. Truck started sounded good, could hear it do the learn, vanes open and close. Let it run for about 20 mins, Took it for a short drive came back and cleaned up. Drove it 2 miles and everything seemed good till I stop at a stop sign, could hear the vanes close then go open and then seemed to be stuck open. Put a new actuator in it and ran the test it opens and closes. But still zero boost. Checked for obvious leaks, not finding anything. No codes no cel. No power no boost and excessive black smoke. What am I over looking...... watching data pid for map sensor when brake torque it goes down to 94 down to 87 instead of going up. Also Checked the air filter, it’s still brand new, checked vane position vs desired and seems to stay pretty close. Also checked fuel pressure desired to actual and it’s staying the same. Don’t see any leaks at the up pipes. It doesn’t build any boost, at all.
