I am wondering if anyone has any ideas as I am at my wits end with this one.
I recently swapped a LBZ into my 99 CrewCab (OBS) ShortWheel Base 4X4. I left the 4L80e behind it. ( I know, I know, it won't last, but I'm pretty easy vehicles so my fingers are crossed). So far just for cruising around its been fine.
The problem I'm having though is a vibration between 1900 - 2300 rpm when in park, neutral and or running down the high way.
The technical details. Stock LBZ, EGR Delete, Intake Air Heater removed, Stock Ring Gear, 06 G3500 Van Flex Plate, GM Torque Converter Bolts, Stock 454 Converter on the 4L80e. I researched this to ensure I was matting the two up as GM did in the vans. (I hope I got it right?)
I have run the engine with the transmission slid back, with no contact whatsoever, and the engine has no vibration at any rpm range.
Slide the transmission back and bolt it up and the vibration is back. This is in park.......no wheels in motion, no driveshaft turning just the converter etc.
The truck is very drive-able at all other rpm ranges. 2600 rpm is great as is 1800. But at 1900 - 2300 I think the trans is coming up through the floor.
I'm posting because I am days away from pulling this combo out and putting in another LBZ/Alli that I have sitting on my garage floor that is completely stock.
I can not stand vibrations and this has me twisted up pretty good.
I don't think its worth puling the tranny and going through it......if that would even solve the problem......if I need to to that I might as well put the Allison in. The transmission when the 454 slug was in front it was fine. No vibrations. It's only since the DMAX came along......and maybe that's it. Have I already broken it and this is just the beginning.
So I need some advice......is that what it's going to boil down to?
Thanks in advance,
Norm
Thanks in advance,
Norm
