lbz lb7 maf differences
1chevy02
Jun 23, 2009
504
I am running a lb7 maf in my lbz. It is throwing a p0101 code. Is there any differences between the sensors? When I log it, it seems to read correctly, but I do not have anything to compare it to.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Same sensors. The P0101 code is a MAF performance code which basically means it is seeing airflow outside of the desired parameters set in the ECM. I have run an LB7 MAF in an LBZ before and it worked fine, so I would suggest looking for intake leaks or an oiled over MAF sensor. Also make sure it is installed in the correct direction.
1chevy02
Jun 23, 2009
504
If I remember it only fits one way? I thought it was the same sensor I was just double checking. It was ran with an oiled filter I believe, so I might try cleaning it. How much will that code affect LBZ performance? Any idea what approx. lb/min should be on a LBZ at full boost? Sorry I do not have another LBZ to compare to.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Don't remmeber what it should flow at WOT as it has been awhile since I logged one. The sensor can be put in backwards, and has been done before. Make sure the sensor portion of it is facing the air cleaner. If teh MAF reading is low, the ECM will limit fueling pretty heavily as teh LBZ bases everything off of an air fuel ratio calculator for max fueling. And this calculation relies HEAVILY on teh MAF sensor working properly to work correctly.
1chevy02
Jun 23, 2009
504
Is there a simple way to disable the maf in the LBZ tune like there is on the lb7? Sorry kinda new to the lbz stuff, been messing with lb7 for to long.
