Cruising around town last friday night in my LBZ, lined up at a stoplight with a kid in a LB7, did a small 15-40 mph roll on the 125hp tune. Drove a half mile and I noticed a small tick. So I pulled over to check things out and my tick quickly turned into a faint knock. Pulled the truck into a parking lot and it developed a very loud knock on the rear drivers side.
Things I have checked
-balance rates are ok except cylinder 4 is at +6 in park
-tried turning injectors off using EFI and every cylinder caused the truck to have a misfire shake EXCEPT injector 4, made no difference in vibration or knock
-Little to no blowby
-no codes
-oil looks fine, no shine or metal chunks
-tested compression on what would be cylinder 5 on a sbc (idk what the dmax order is) and it tested 180psi so i pulled the motor and trans.
I suspect a rod? I don't think I have ever heard of a "stock" LBZ bending a rod with such a mild tune. Any ideas??
-no codes
