LBZ into a 1500hd mess
leathalbusa
Jan 1, 2018
Hi All
I have been reading on here for awhile now.
I am currently in the finishing stages of the LBZ into my 1500HD. what a trial.
Lots of wiring changes and chasing as the vehicle is right hand drive.
Ok I have been reading the posts on the conversions. and i have a couple simple but trying to clarifing questions.
1. i am using the LBZ fuse box and engine harness. Do i still move the wires on the Connectors? C2?
2. I am using the LB7 cab harness and have moved the pins in the cab side plug C100 i think. when i pull the change the pin locations of the Brown and yellow wire. do I tie in the wires that I have pulled out? or just leave them out of the system?
I will post more about the trials and tribulations of this build. as am more trying to get it sorted as am running out of time before i need it on the road.
Kriesel
Apr 2, 2013
25
Afton, MN
What year 1500HD?
You will likely still need to move wires in either case to match what the LBZ wants to see.
On the plugs, some of the colors should be the same on each side, and I wouldn't tie together unmatched colors...
