LBZ: LBZ intermittant Check Engine Light
MM46
Apr 27, 2014
Georgia
I would appreciate any opinions. 2006 2500HD LBZ. I purchased the truck 2 weeks ago and am new to the Duramax platform. I have had 3 instances of the check engine light in 2 weeks. It comes on, typically stays on for 30 minutes run time, goes back off. I've not had the codes pulled yet.
Are there "typical" issues on the Duramax that are the usual suspects on a check engine light? Sensors to check, etc?
Might need an EGR value cleaning, but wanted to see what other culprits might be lurking under the hood.
Opinions welcome, good opinions particularly valued!
MM46
Apr 27, 2014
Georgia
its stock.
Has only come on when cranking, never while running. Pretty small sample size though.
Yep, agree on pulling the codes (but haven't yet found a trusted Duramax guy). Seems you can't throw a rock without hitting a good Ford PSD guy, Duramax folks are fewer/farer between, in my part of the country.
13,746
821
Most auto parts stores can check codes for you for free.
MM46
Apr 27, 2014
Georgia
ok, pulled codes. P2563 and P003A. Looks like stuck vanes. I pulled other threads on these....looks like a turbo cleaning at a minimum.
Thanks
