a regular bridge wont work?
Thats a stock LBZ y-bridge , what Henry is talking about is taking the van bridge he pictured and cutting the stock piece off the top and welding your own pipe to it that mates up to the stock IC tube . I have built customs ones using both the stock piece and the van , the van is much easier because you dont have to weld the front hole off , but is 100 bucks so ................... other than that the runners should bolt to LB7 heads and the rest should work .No, that's not what I have. I have two pieces. The lower half, and a slip fit pipe that's a hard 90
once I get mine back from my welder, i'll post a pic, it's very similar to Ricks pro-flow lbz bridge. I used a stock lbz bridge and am having a divider welded inside to direct even flow to both banks. with a 3" 90* inlet pipe welded to a bushing i had made to take up the extra room.
Knockin' on 10s and when the hood is closed who knows if you didn't make it like you wanted the first time. Nice time which pistons and rods are you using? Just see the stock piston let go.
Be neat to see how it turns out I just dont see the bend giving enough room. I wish I used a Van bridge on my truck when we did this mess.
Maybe mount the turbo alittle higher would of made the intake cleaner. But Still not enough room without a tight bend.
Guess I cant cry to bad lol still ran 11.53 with this junk setup on it.
