I've been having issues with my cluster lately and just last night it stopped working all together. If I can't fix it and have to buy a new one. Would a cluster from an lbz work?
Yeah I knew about the mileage part. I know enough people at dealers who can do that for me. I just wanted to make sure it was a plug and play kind if thing. Thanks for the quick response :thumb:
work perfect without programing I have one had it in for 60k miles I found one with similar mileage and just threw it in no problems
no not completely perfectly.......
overdrive lockout light wont work.
And when you manually shift to "3" or "2", the gear indicator display on the cluster will go blank. So the LED underline on the gear display will only work in Park, Reverse, Neutral, Drive, and 1.
I'll check my parts stash. I may have a cluster that would fit an lb7 in a box.
I have the fleece tapshifter so would the gear I'm in show up on the dash still.
If you find it let me know. I had a half tank when it went out so I'll fill the tank and hope everything is good until I get a new cluster.
The tach is the same, that wont make a difference. All duramax tach's (2001-2014+) are 0rpm-5000rpm. Only difference is the overlay. So the tach will read the correct rpm because the numbers are in the same spot and the stepper motor is calibrated exactly the same.
02 and 03 are different clusters.Contact Everett. He just took one out of his 02 project truck.
http://http://www.duramaxdiesels.com/forum/showthread.php?t=51109
