LBZ FPR on LLY
Operator1
477
NC
The LBZ FPR is supposed to flow more than the older ones. I don't think its much more, but every little bit counts. I put the whole LBZ pump on mine because my old one couldn't hold rail pressure any more. The tuning needs to have the regulator current changed to get the pressure control right at low rpm.
mispeeld with tapatalkz
2,064
More flow. Adjust the low ranges of the B1010 table until idle is smooth, otherwise you get an annoying lope.
Bobo
Aug 27, 2006
271
I see a lot of guys running LBZ FPR's on LB7's and LLY's. What is the advantage? What tuning adjustments should be made?
Thanks.
If you are spending the coin to do that, you might as well upgrade the fuel lines from the tank up to the CP3.
paint94979
Beer Nazi
Sep 18, 2006
11,715
I added a stock LBZ Regulator to my 30k LLY pump... I held 22,000-23,000psi all the way down the track. According to my logs my RP would spike to 25,000psi for spurts as well
