Who makes a good one that wont break the bank? I found one around $250. Will driving with the engine light on hurt the engine long term? I really cant afford anything till spring. thanx
Pull the EGR off, remove the passenger up-pipe, cut off the EGR tube and weld it up. Then use some 1/4" plate to block off the motor ports on the intake and you are done. Don't forget to make a bracket to support the intake. Now you have an EGR that is gone and you spent a whole $5.
