Lbz Duramax help
LBZDirtyMaxx
Oct 21, 2020
I keep getting P2155, PO203, AND P0203. Brought it to the dealership because it's too cold out where I live and no garage and they got the codes to stay off and test drove it. They thought it was fixed because they could not get the code to come on again. Go to grab some lunch today and all 3 codes came back. Hoping someone has knowledge of service bulletins because dealer couldn't find any. PXL_20201009_225115902.jpg
Sent from my Pixel 2 XL using Tapatalk
1,187
Found this for the P2155 code.
heres the diagnoses from GM's service information for ya. when it comes to checking resistance in the injector dont forget to check from pin to housing of injector, it is possible it is shorted internally
Circuit/System Description
The engine control module (ECM) supplies voltage to each fuel injector on the injector positive voltage control circuits. The ECM energizes each fuel injector by grounding the control circuit of that fuel injector. The ECM monitors the status of the injector positive voltage control circuits and the fuel injector control circuits. The injectors are separated into the following four groups:
•Group 1–DTC P2146 with injectors 1 and 4
•Group 2–DTC P2149 with injectors 6 and 7
•Group 3–DTC P2152 with injectors 2 and 5
•Group 4–DTC P2155 with injectors 3 and 8
When a fuel injector circuit condition is detected by the ECM, the fuel injectors in the affected group will be disabled and set the group DTC and may also set the fuel injectors DTCs.
Conditions for Running the DTC
•The ignition is ON.
•The charging system voltage is between 6–18 volts.
Conditions for Setting the DTC
•The ECM injector output driver detects an incorrect current on a fuel injector circuit.
•The above condition is present for 3 seconds for groups 1, 2, and 3.
•The above condition is present for 5 seconds for group 4.
Action Taken When the DTC Sets
•The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
•The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
Conditions for Clearing the MIL/DTC
•The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
•A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
•A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
•Clear the MIL and the DTC with a scan tool.
Reference Information
Schematic Reference
Engine Controls Schematics
Connector End View Reference
Engine Control Module Connector End Views
Electrical Information Reference
•Circuit Testing
•Connector Repairs
•Testing for Intermittent Conditions and Poor Connections
•Wiring Repairs
Circuit/System Verification
Important: If you cannot duplicate the condition, operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records.
 1. Observe the Balancing Rate parameters with a scan tool. The normal reading should be between +4 mm³ and −4 mm³ at idle, and between +6 mm³ and − 6 mm³ in drive. With the engine running at idle, the Actual Fuel Rail Pressure should be close to the Desired Fuel Rail Pressure.
 2. Engine running, observe the DTC information with a scan tool. DTCs P2146, P2149, P2152, or P2155 should not set.
 3. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Circuit/System Testing
Fuel Injector Group DTC set
 1. Turn OFF the ignition. Allow 60 seconds for the ECM to power down.
 2. Disconnect the ECM connector.
 3. Connect a test lamp between the fuel injector positive voltage control circuit and battery voltage.
⇒ If the test lamp illuminates, test the fuel injector positive voltage circuit for a short to ground.
 4. Test the fuel injector positive voltage control circuit and the fuel injector control circuit for high resistance.
 5. Test the affected fuel injector for high resistance. Refer to Component Testing in this diagnostic.
⇒ If all circuits test normal, replace the ECM.
Fuel Injector Group DTC and Fuel Injector DTCs set
 3. Connect a test lamp between the fuel injector positive voltage control circuit and a ground.
⇒ If the test lamp illuminates, test the fuel injector positive voltage control circuit for a short to voltage.
 4. Connect a test lamp between the affected fuel injector control circuit and battery voltage.
⇒ If the test lamp illuminates, test both fuel injector control circuits of the affected group for a short to ground.
Component Testing
 1. Disconnect the connector of the fuel injector to be tested.
 2. Connect a DMM between the terminals of the fuel injector and measure the resistance. The resistance should be 0.2–0.3 ohm.
⇒ If resistance is more than 0.2–0.3 ohm resistance, replace the fuel injector.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
•Fuel Injector Replacement
•Control Module References for ECM replacement, programing and setup
1,187
All I could find for the P0203 is this and all seems to be on LLY But maybe it will relate.
#06-06-04-026A: LLY Intermittent SES/MIL Lamp Illuminated, Reduced Engine Power, Fuel Injector Driver Circuit DTCs P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208, Cylinder Bank Shut Down DTCs P2146 or P2149 - (Dec 8, 2006)
Subject:LLY Intermittent SES/MIL Lamp Illuminated, Reduced Engine Power, Fuel Injector Driver Circuit DTCs P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208 and Cylinder Bank Shut Down DTCs P2146 or P2149 (Replace Affected Injector Connector Pigtail Harness)
Models:2004-2005 Chevrolet Kodiak C4500/C5500 Series, Silverado Models
2004-2005 GMC Sierra Models, TopKick C4500/C5500 Series
with 6.6L Duramax™ Diesel Engine (VIN 2 -- RPO LLY)
This bulletin is being revised to update the Kent Moore tool number used on inspecting the injector connections. Please discard Corporate Bulletin Number 06-06-04-026 (Section 06 -- Engine/Propulsion System).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss1-1876986">Condition
Some customers may comment that the Service Engine Soon lamp is illuminated and/or intermittent along with a significant reduction in engine power (limp home mode). Upon investigation, the technician may find one or multiple injector driver circuit diagnostic trouble codes (DTCs) P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208 and bank shut down DTCs P2146 or P2149.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss2-1876986">Correction
Important:
If the published diagnostics lead to an injector connector on cylinders 2 and 7, the 2 and 7 cylinder injector connectors must be repaired and supported as per bulletin 05-06-04-047B.
If the published diagnostics lead to an injector connector on cylinders 1, 3, 4, 5, 6 or 8, replace the affected injector connector pigtail harness with P/N 88988963 using the following repair procedure.
  1. <LI type=1>Complete normal SI diagnosis for the trouble codes set. <LI type=1>Injector circuit or injector coil tests may be normal until the engine reaches operating temperature. Recheck circuit/injector resistance readings with a warm engine. Important: Dealer technicians are to repair wire chafes at the Fuel Injection Control Module (FICM) as needed. Follow the correct SI wiring repair procedures. Insulate the harness from the aluminum retaining bracket with suitable material (electrical conduit or heater hose) so the harness will not chafe again.
    Important: When diagnostics are being completed for Injector Driver Fault codes, the dealer technician may notice the Fuel Injection Control Module (FICM) connector is wet or has a wet residue on it. The FICM connectors do have a type of dielectric grease that may be mistaken for diesel fuel. The FICM should not be replaced if this type of wet residue is found. Clean and dry the connectors as needed. No extra dielectric grease needs to be added to the FICM connectors.
    <LI type=1>Inspect for wire harness chafes on the Fuel Injection Control Module (FICM) wiring harness retaining bracket. This is an aluminum bracket very close to the FICM connectors. If any part of the taped portion of the harness is touching the FICM wiring harness retaining bracket, then you must look for chaffing on the wiring harness. It must be disconnected from the FICM and bent back towards the engine. Look for any chafes into the tape. If necessary peel the tape from the area and look for any chafes into the wires. Some of these chafes are very small, possibly the size of a pen tip, but could still cause injector circuit concerns. <LI type=1>If diagnosis is inconclusive, inspect the injector connections on all related cylinders. Pin drags and terminal tension can be checked with Kent Moore tool number J 35616-35. <LI type=1>Clear the trouble codes and then wiggle test the related injector connectors to see if the trouble codes can be induced. If the vehicle had only injector circuit codes for P0202 or P0207 (with bank shutdown P2146 or P2149), and the wiggle test induces a P0202 or P0207 to reset, use bulletin number 05-06-04-047B to repair the injector connectors and install the injector harness support kit.
  2. If the trouble codes or customer concern is induced during the wiggle test on any other cylinders (other then P0202/P0207), replace the affected injector connector pigtail with P/N 88988963. This replacement pigtail can be used to repair any cylinder except number 2 and number 7. The 2 and 7 cylinder connectors must be repaired and supported as per bulletin 05-06-04-047B.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss3-1876986">Parts Information
Part Number
Description
88988963
Pigtail Harness, Fuel Injector Connector
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss4-1876986">Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N6606
Wiring and/or Connector-Fuel System - Repair or Replace
Use Published Labor Operation Time
