lbz build help
brandon06dmax
the reckoning
Apr 29, 2013
365
jactionville nc
having some work done to my lbz current mods are 5 inch mbrp exhaust 165 air dog built trans efi live s&b intake pretty much a bolt on truck with a trans now im getting the trans redone hopefully better than it was now im 95% set on a s475 double bat but my big deal come in here i not sure if i should do 45% injectors stock cp3 or 60% overs on dual cp3s i am going to build a motor but dont wanna blow it before i have a new motor built so can i do dual cp3s and 60% and tune it down safely i would like 685 rwhp on a big race tune and 575 daily driver on a stock motor ill be looking for more once the motors built but 4 now
PACougar
2,105
41
El Dorado Hills, Ca
I would do 100 overs and dual cp3, just run a really conservative tune. This way once you build the motor you won't have to spend the money again on injectors.
1,868
*shakin my head* Save your money, build the motor first. For what your goals are, its silly to do things backwards.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I'm still just a :baby: here but here is my advise...
If you want to have patience, build your block first, then run dual pumps and 100% over injectors, I would prolly still run exergy 10mm cp3's in this set up, with a 4094vgt and a 4788 over it and you would have a sweet set up,(you could go real big and do a 42/55 set up) or Borg equivilant would be just as good I suppose, but I like Garrett stuff. This set up should get you to 750whp with ease, massage the turbos a bit and 900whp should be possible, and I have been told runs cool enough to tow with 650whp
Or if you want, you could upgrade to the 4094 now and run 40% overs on a conservative tune and be ok, still , might/should need a moded cp3 to keep up with the injectors, this would put you well over 600whp. Not sure how long it would last(your pistons) depends on tune, and how you use it(as always, built or not) I have been told that dual pump on stock internals is a recipe for split pistons and bent rods, but do what you want
One of the Danville guys was runnin a vgt 72 a 10mm cp3 and iirc 40% injectors and he did fine for a year or more at your target goal of 685whp or close to it...
I wouldn't push your stock block to the brink unless you have the coin to build it the right way when it breaks, and another vehicle to drive in the down time, also, another thing to consider is the g-80 in the rear end, it's not gonna like all the added power, mine didn't, and it let me know by locking up and puking out chunks of metal, this was at 600whp and considerable abuse, add another $1200 for a Detroit truetrac and the labor to install it along with fluids. Just food for thought.
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
i was thinking ridge runner diesel or kor willis 4 tunning do u think i can turn 100s down low enough to be safe
Can't speak for tony, im sure he can, but I know kory can. Hes doing it on mine right now. I'm just waiting for the time to throw my second cp3 on. Very conservative tuning. Just can't be mad if/when she pops.
brandon06dmax
the reckoning
Apr 29, 2013
365
jactionville nc
I want a lot more power once the motors built but I think I'm going to run 60s on conseritive tunning unroll its built I'm starting the build on the motor next summer hondarider552 do u like your 475
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
I also have a s400 but a 72mm, stock fueling with a lbz fpr on the pump. There isn't nearly as much lag as people make it out to be. Very fun charger from
What I have noticed thus far. Tony's retuning mine this weekend so it should lite up and perform even better! I should have went with the 75, being the same
Price.. Lol. I bet with dual fuelers or a big cp3, the thing would be a beast!
04D_MAX
force fed
Sep 10, 2012
384
SOUTH GA
dont think his motor liked it...
picture.php
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
Yooo Daniel lets play a game! Lets play put it on 5 and see how many times we can go WOT this weekend! Maybe donuts behind the house with glow sticks!
Haha
brandon06dmax
the reckoning
Apr 29, 2013
365
jactionville nc
thanks guys ive pulled the trigger s475 tct 60% injectors stock lbz cp3 i hope with kory's tuning that it will be a safe 550 dd and on its race tune it will be down right nasty hopefully somewhere in the 115-118 et mph and dont worry guys next year when i finish the motor ill throw dual fuelers on it and watch the bottom end fire works
