LBZ Allison into a LLY truck
ChevyTruck
Boats an Hoes!
Oct 19, 2011
449
Newark, De
Would a 07 Classic LBZ Allison go into a 05 LLY? A friend of mine flipped his LBZ and got a LLY now, he bought the truck back, wondering what it would take to do the swap if possible.
Thanks in advance! :)
P.S. not sure if I have this in the right section or not, if not please move it.
15,681
233
The '07 trans will bolt right up to the '05 and it will work as a 5 speed. You will need to change the valve body, internal linkage and harness and use the NSBU switch off the '05.
blackdirtymax
Apr 15, 2010
825
augusta, ga
Can you turn a 5 speed into a 6 by changing the valve body and harness. Basically putting an 05 Trans into an 06 ? Just curious
Built motor , duel fuelers , 60's overs , gtx4202r
