We've got a lbz/allison/combo here thats getting shoehorned under the cab of an early 40's ford cabover. We are at the point of connecting the shifter to the street rod style ididit column we will be using in this truck and I have a questions in regard to the shifter and it's detents. My question for your trans gurus is how many detents are required for proper operation? Obviously P,R,N,OD,D ?? but beyond drive or OD how many more positions are there? I'm not sure it I will be integrating the tapshift feature in this build either. If i can delete it i likely will. Can you manually pull the lever into low gear or is it computer controlled?
