Lby
bronson
Apr 3, 2008
101
Sylvan Lake, AB
You and me are at the same point then. What are you doing for internals?
I got some LLY pistons (16:1) and rings, Carrilllo rods, HP push rods and standard rod bearings from David at BMS machine (saw his ad in the Garage sale section of this site). Good deal too.
Im not changing the cam and hopefully not the injectors, the piston was cracked and not burnt up so they should be ok..... Ted is pulling the motor apart towards the end of the week so we will know more about the block and bottom end then, but it should be ok, i shut her down as soon as it went.
What are you planning to do to yours?
Alligator
Nov 9, 2006
1,919
N. Idaho
SoCal Cut/Coated pistons, Rods, new bearings etc... The list will grow, want to wait until I see the motor.
