I know this is a long shot without any knowledge on the truck but here it goes. Bought the truck needing a trans installed.
It’s a 2003 short block with all lly top end. All lly electronics is what it looks like and was told. Lly turbo, ecm, ficm, tcm, engine harness, and harness to fuse box. The truck is acting like the common lly issue with surge/lope only when warmed up, No codes. When being easy on the throttle it surges also. I have a log of it. Sounds perfect when cold then pretty bad rattle when warmed up. I’ve checked the Normal lly issues, wire harness rub, ice picked, fpr replaced. Stock tune and modified tune same thing. Throttle seems very touchy I low rpms/gears. I do know the fuel gauge reads backwards which I’ve read is tuning. Any ideas?
