Lb7 y bridge help
Hnkstang50
NJ
What is the easiest way to get a lb7 y bridge out? I have all 4 bolts/nuts remove on both sides. It's hitting the high pressure block that the rail pressure sensor is on. Do I need to remove all 3 of the lines that bolt to it and remove it? Is there an easy way to get it our of my way. I was hoping to not have to dig much deeper but that block has no wiggle room currently
Thanks
Dukchunter
57
Just take the fuel lines off. It's really simple then your home free
Hnkstang50
NJ
Ok thanks. Kinda what I figured but was hoping I could sneek it out somehow. I just need to get all the wires out of my way first
Any one have torque specs for the fuel lines. Hp lines is something I would like to torqe properly if I can
Dukchunter
57
30 ft lbs on high pressure lines... I've had them leak at that torque so I always use the good and tight method.... lol
1,941
I was going to say, "A really big hammer", but looks like you two figured it out. :roflmao:
