i just got my pickup put back together after doing rods and mains, took it for a test drive and it wont shift when in D, shifts in to P, R, N and D. It has a U1000 code and P0700 but when i try to check the transmission codes the scan tool cannot connect to the tcm to read codes.
Ive cleaned the battery cables, the grounds, tested power and grounds to the tcm and checked the serial data wires and they all tested good. Is there anyway to test the TCM to see if its bad?
