LB7: LB7 with P1261 & P0206
dirty_maxxbob
Jan 19, 2015
24
3
ca
What are the odds the injector harness below the valve cover is bad? About a month ago I lashed the valves and since then haven’t driven it much. Over the last few weeks I started driving it to work. Monday I noticed it had a slight knock as I pulled up to work. Went to go home and checked the oil, was clean and started it and within a few minutes of it idling these two codes popped up (P1261 P0206). My truck never had the new injector harness put in from the recall. Previous owner had replaced one harness but on the other bank. Injectors are still somewhat new with good balance rates (1.2 is the highest). I just finished giving it a once over and I haven’t found any rubbed threw wires either. Only two possible things, FICM or the harness under the valve covers. Any thoughts before I order anything
warriorcustoms
Oct 5, 2017
24
Leon OK
Pretty sure the only way GM wouldve replaced any LB7 injector harness is if it Broke from too much tension!!! IF it came off theres the Ice Pick trick but I was thinkin that was mostly LLYs... Ohm out the injectors with a multimeter & it will tell Ya lots about what May be goin on...
dirty_maxxbob
Jan 19, 2015
24
3
ca
That’s what I plan on doing. I ordered 2 new harness just because, plan on tearing into it this weekend and seeing if I can find the Cause. I just hope it isn’t the Injector that took a shit lol I have exergy 45 overs with sac tips, those be expense and take a few extra days to get
