Here's the rub. I have a 2001 Silverado 4x4 with a toasted LB7. It has been overheated until the pistons and cylinder heads melted, camshaft spun a bearing, etc. This engine is no good, except for the crankshaft. I was gifted a 2007.5 Silverado 2wd with LMM. The LMM has a broken crankshaft. I'd like to take the LB7 crankshaft and build the LMM, then put all the 2007.5 (stuff) in the 01', several different ideas here.
1. Swap everything over, dash, wiring, everything. This would leave the 4x4 problem if I managed to fit it all in the 01'.
2. Use LMM heads, and injectors. Will the LB7 harness work with these injectors?
3. Just build another LB7 and use the transmission and TCM from 2007.5 to get 6'th gear.
Open to ideas, I know this is going to be a lot of work no matter which approach I take. I'm trying to keep it low budget. The only engine upgrades I plan for is a fluid dampener and alternate fire camshaft. I'd like to get started ASAP, but I need to order parts and right out of the gate the PN for the Fluid Dampener is different for LB7 then LMM.
