LB7 with 40 engine codes
Kodiak440
Oct 6, 2024
Mitchell, Oregon
Truck started running rough and blowing white smoke that reeked like diesel. Had the injectors changed and egr delete but the problem still persists. The engine light never came on but there are 40 engine codes on it. Previous owner had a Quadzilla Stealth 2 on it which i got rid of. Here is a list of all the codes, if someone could point me in a direction that would be great.
p0101, p0116, p0128, p0181, p0236, p0300, p0401, p0404, p0490, p0522, p0540, p0543, p0833, p1172, p1404, p1630, p1637, p1642, p1875, p2066, p2067, p2068, p2142, p2145, p2227, p2279, p2610, u1000, u1099, u1255, u1024, u1016, u1301, c0306, c0327, c0359, c0379, c0550, b0790, b2725
dirtydmax
<---up shit creek
Sep 1, 2013
1,087
46
muskoka,Ont Canada
If batteries were hooked up when bail connectors were separated to do injector job that's most likely where your codes came from.Truck's still running rough blowing smoke is prob a hard part failure but clear coded and re check.Ballance rates?
Kodiak440
Oct 6, 2024
Mitchell, Oregon
Any change with for unplugged?Check fpr pigtail
I will check this
Mine ran,fired right up as well but white smoke/ raw fuel and and ran like shit as well once i started driving.We're you into valve train at all?
Never got into valve train or timing, it just randomly did this when going down the highway. Took it to a shop and they told me injectors. Then it sat in the shop for 6 months because they couldn't figure it out after the new injectors didn't fix it.
dirtydmax
<---up shit creek
Sep 1, 2013
1,087
46
muskoka,Ont Canada
I will check this
They couldn't figure it out in 6 months?Did you use genuine Bosch remains or a set from a less reputable vendor?
Kodiak440
Oct 6, 2024
Mitchell, Oregon
Just out of curiosity did you check for blow by?Any chance you have pushed in pins in bail connectors?Strange symptoms for sure
I'll check the bail connectors, truck has no blow by. Could the ecu or ecm be goin out? Seems to not be able to communicate with any of the other modules. Now it says service 4wd, seems everything is failing.
1,816
Sounds like a canbus or grounding issue to me.
How did you "delete" the EGR? Did you use the old-school fingerstick and blocker plate? Or was the stock tuning changed to reflect it?
