lb7 vibration misfire. injectors?
strongsperformance
2002 sierra cc dually
Jan 14, 2011
78
lake orion michigan
Well guys my truck has finally acted up on me.
Ok to start it off I turned off a side street and stood in it after the converter locked thru third gear. I let off pretty much coasted to my house. I get in the driveway and notice the truck is shaking like a cylinder misfire.
So today I hook up a tech 2 I am a newbie so I'm not sure how to use it but seemed easy. I looked at my balance rates and they are all within spec except number 5 it is at like 3.5 but I've seen 7.2 in gear.
Here's my thought I can turn off injectors individually but cyl. 5 makes a big difference but 1-8 do very little when injector is turned off.
I am not sure if the issue. It seems to of got worse now that I went out and ran it hard once.
I am not sure where start looking for answers.
I am going I didn't bend a rod. Idk
strongsperformance
Jan 14, 2011
78
lake orion michigan
What do you guys think about a possible balance pin shearing?
Just don't know where to start. Cash is tight to just throw injectors at it.
Update:
Went out pulled belt off and then reached up and removed balancer bolt with my fingers.
I'll be looking at balance pin in the morning.
