What's up everyone! My '02 LB7 is having an issue. It's using more coolant than what I think is normal. 175K miles and the engine is pulling strong as ever; No signs of a leak; Blowing clear exhaust. Thoughts?
Just replaced the water pump on mine. Had the system pressure tested, leaking from weep hole in pump. Garage said 8 to 9 hours and wanted $875 to replace pump. I replaced pump in 3 hours for $125. Have it pressure tested to verify leaking area.
