LB7: Turbo replacement question
WisconsinHick1
Mar 11, 2009
1,231
Minnesota
Alright I swapped in an S366 and pieced together my own kit but ran into a problem. I need a plug for the coolant line that use to run to my stock turbo. It is the fitting that sit on top of the coolant line. The turbo coolant feed line. The return was easy I just cut and welded the hole shut. I either need to find a plug for the fitting or need to find a pipe to replace it.
Any help would be great.
KEVINL
1,431
Phoenix, AZ
I agree and it creates some more room but if you have the kit and don't have a plug thats your best option
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I get plugs here in town for the guys that need them. I've shipped out probably ten. Just trying to help guys out as I have access to lots of metric stuff.
