Quick question - at even 2lbs of air from the inlet of the s475, I have air leaking past the “snout” bolted onto the front of the ihi. Is this a problem area and I should attempt to seal it up? (WCFab compound kit). Thanks!
I siliconed mine to the front of the ihi to stop the leak. Also had a leak at the v-band at the outlet of the big turbo but swapped pipe flange to have an o-ring seal.
Thanks. That will be next. I’m shot from working on her in this heat! Last 5% takes
90% . The storm is starting, so I’m taking another shower. Yuck. lol
Thanks for the part numbers! I’m looking through my spare parts and I have one. I guess copper rtv both sides and install? Not sure what else in the local stores would hold temps better?
