LB7: LB7 s369sxe
bigmackmiller
1,046
Kokomo, IN
Hey guys, I am wanting some opinions on a turbo upgrade. I purchased a pieced together s300 kit on a Craigslist find. It came with a HSP pedestal, fleece install kit w downpipe, charge pipe couplers, S369sxe, and an ats intake. Will I need anything else to replace my factory IHI? Considering upgrading charge pipes, ybridge or both, truck is currently running 65% SAC inj. And have a 10mm ready to go on, tuned by Mark @ Danville
ZeroGravity58
1,401
51
Maryland
If your going to do a y bridge, best time is with the turbo out. Also if it has a lot of miles on it the up pipes can be a pain to get off. If you plan to do up pipes and manifolds it would be easiest to do it all at once.
ZeroGravity58
1,401
51
Maryland
I've had the best luck with the profab manifolds and up pipes. They come with all new hardware so if you break off a bolt on the old stuff it's no worries. I can't remember for sure as I haven't had or worked on a lb7 lately but I'm pretty sure the factory intercooler pipes are 3". Someone will check me if I'm wrong
Antiher03
Nov 10, 2013
165
Utah
You will also need coolant plugs and a plug for the valley oil return.
