is the prv valve on a lb7 on the small manifold in the valley between the two main rails and if so which side is it on on the manifold driver or passenger
Not sure if the lb7s have a hose nipple on the end of the FPRV or if it's hard line, but you should try doing a bottle test if it does have a nipple to hook a hose to
