LB7 pass side up pipe
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Blew my egr bellow out tonight on the freeway racing a ricer, much above 3psi I can hear it and it tore a hole in my firewall padding :spit:
LB7 pass side up pipe, I read it somewhere but cannot find it :eek::eek:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Thank you sir!! :thumb: :hug:
I removed my up pipe and found the problem... this was only after 1 week of driving, and 200 miles on the turbo. I learned that not all shortcuts work like you think :eek:
EGR riser pipe.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Did you have the EGR riser supported at all where the cooler bolted on previously Brian; How was it blocked off? Do you have a pic from further away showing the whole EGR riser and where it attaches to the up-pipe?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
No, I did not. I made a bracket for it, but the downpipe pressed the riser towards the front of the motor so I scrapped the idea. I made a steel plate for the blocker, lemme find a pic of it.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
The DP for the HTT? I sourced an LB7 up-pipe after paul and I talked about this but the pedestal bolt look like a bitch to get to. I had some small sq tubing and I had thought about bracing what is there and replacing it if it broke. It's just real cold out there right now :baby:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Yeah, the downpipe for the HTT pushed the bellow forward. id assume that it pushe dit farther than the bellow would normally bend and a small crease became a crack. the Pedistal bolt wasnt that bad to get, I just had them off a week ago so used a 3/8's rachet like 6" long and a 1 foot breaker bar and they were off.
13,765
834
Did you drop your trans or can you get to it from the side/top?
Pull the downpipe and passenger's side fender liner and work through the wheelwell. That's the easiest way I've found to get to it.
Jun 28, 2007
3,259
NE Pa
X2 Josh is right on the money.
There is absolutely no reason to drop the trans to do up-pipes. I have pulled them hundreds of times.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
No, not the dreaded downpipe ! I swore I would never take that back out after all the hell I had getting it in there ! :spit:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Nope, I may have the only LBZ that has tons of room once I get the downpipe off, I can almost stick my head back there..lol
I can get all the up pipe to pedistal bolts from the pass side.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Got the new lb7 up pipe on, and no leaks, had a hickup with the V-band clamp not lining up, but it was user error :rofl: No rubbing, and no leaks, good day IMO...
