Lb7 p2146 p0206 p0204 p0201 p0207
Jwskin69
Sep 5, 2024
Wyoming
I really need help with this one found out injector number one with showing 0 ohms replaced it but it all back together and it's still showing all these codes all the resistance on all the other injectors check out good what could it be
2,059
Need to check inductance with an LCR meter. You can check it through the FICM harness. If an injector is half shorted out it may read ok on the ohm test but not for inductance
I'd also check that you have power on the bank one supply line since all the bank one injectors are affected
