ive got a 03 LB7 with efi live and i recently went to BD S364 supermax turbo and now i get a p0234 turbochager overboost code, what tables need to me modified to get rid of those code/defueling.
Easiest way I know to stop it is to go to B0202. Start at 3.28 volts and up and set it to 36. This will keep you under the max boost pressure regardless of what the boost sensor sees.
ok thanks i'll try that, and turbo sounds awesome, and right now with the overboost code it spikes to 38 then it starts to defuel and limits it to 30psi.
