Hey all, duramax starts runs and then dies basically immediately
was going to wire up my boost gauge (didnt even bother after this)
Use to have a BT diesel automatic high idle that i couldnt get to work (ages ago) that i had just cut out when i removed it.
i accidently touched one of the wires against the steel under need the column and it made a spark then and now the truck wont start
dash lights also wont come on, i checked a bunch of fuses but im not sure what im missing, any ideas?
here is a video
http://www.youtube.com/watch?v=yIfeBbaUlGw
And I think these were the wires
read back on the instructions and "NOTE: YOU MUST USE A POWER SOURCE THAT IS “HOT” DURING “RUN” AND
“CRANK”. (ie, a power source that does NOT momentarily shut off when the key is turned to
start) A known-good location to tap into an ignition-hot source that is hot in RUN and CRANK, is
at the BCM. Locate the 24-pin LIGHT BLUE connector on the BCM."
but i honestly cant remember where this one went, it goes up to the column and yeah. guess i shorted it out.
not sure if this would help
is fuel being cut from the security system or something like that?
thanks
here is a video
thanks
