lb7 low rail pressure
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I have a 2002 lb7 that has a 1093 low rail pressure and a regulator performance codes... I hooked up efilive and rail pressure is nearly 10,000 psi. I rev engine and rail went up, still above commanded. FPR is clearly bad. I command 160 MPA at idle, stays at nearly 10,000 psi. So I assumed injectors were returning excessively.
I tore into it to perform the correct bottle test, I have a banjo off each head and from cp3. I ran the truck shortly, 20-30 seconds and had 16 ounces from cp3 and not really measurable from each injector bank. And nothing from the relief valve. I disabled injectors and cranked for 15 seconds, 4 ounces of fuel from cp3, and hardly drips from each injector bank.
I searched and searched, I cannot find an allowable leak rate from cp3?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Sounds like the regulator is stuck in one position.
Sorry, I don't know the return spec.
onebaddmaxxx
1,212
Cecil County Md
Take the fuel filter off and fill it with transmission fluid and reinstall. Seen it get rid of surgey regulators and help balance rates. ATF is very lubricative.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Switched out FPR, idles at desired now, still only makes 14,000 to 16,000 psi at idle, rev it to 1250 rpm and it will make 22,000 psi...
Must need a cp3.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
How many miles on the truck?
Sent from my SCH-I535 using Tapatalk 2
25x,xxx miles, I've honestly only ever seen 2 failed cp3's before, one was a less than 20,000 mile 85% industrial injection POS, other was an over 200,000 mile lb7 and it would do really flakey things. I'm pretty hesitant to put a cp3 in anything, lol. My little brother's '06 DMAX has 335,000 miles and will hold 21,000 rail pressure on a 535 hp race tune with no lift pump, lol. I think the only reason it doesn't maintain is the injectors are, I'm sure returning a little excess fuel from wear...
I just don't see them fail enough to assume it could be the problem...
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
If you do some searches you will see 01-02 trucks seem to lose CP3's around 200K miles. I know I was warned to do mine, and didn't. Well at 200K miles mine started getting hard to start because the CP3 had failed. And the return spec for the CP3 is 1.8 onces(25ML) IIRC(I'm not 100% on what it is, but it shouldn't return much).
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
I'm getting 4-5 ounces in 15 seconds of cranking, and 16 ounces with 15-20 seconds of running...
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
This one is starting right up when cranked, I've done injectors on multiple trucks that started hard and had insane fuel return from injectors, and one lb7 with a leaking relief valve, I was expecting injectors on this one when it wouldn't make 23,000 rail pressure at idle.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Just did one on a 02 and it was return alot of fuel but had not hard start issue. it would only run 5-6k going down the hiway. changed it out yesterday and its all good now.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Pumps are kind of a crapshoot. Ive seen stock one's fail at 90,000 miles. Some strong at 200,000+.
Bad fuel, filter maintenance, poor quality filters, and running them dry by running them out of fuel all play a big role in pump life.
Regardless, I wouldn't waste the money on a regulator on a high mile pump. For the money difference between just a regulator and a whole new pump, and the amount of labor involved to swap either one I would always recommend a new pump on a high mile pickup.
Glad you found the problem at least.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I went and rechecked my notes, and the CP3 return spec is 1.2 onces or 20 ML for 15 seconds of cranking with the injectors disabled. Anything more and it means the rings in the CP3 are shot and it is just pumping the fuel out the return instead of to the injectors.
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
SWEET!!! That's what I was looking for and now it's a permanent note in one of my own threads to look back on! I couldn't find an amount of allowable return on ShopKey or Google searching. Thank you very much!
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Pump fixed it, I could freewheel old pump with little or no resistance unlike other used pumps and the new pump, it spikes to 24,000 psi and runs at 160 Mpa at idle now.
