Lb7 lost low end power
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
Well, while driving down the road, seemed to have lost low end grunt..
At the next light, it was a pig..Seemed to have lost all low end until 2700 rpm, then it woke up and wanted to run..(kinda like NO tune driving)
no smoke, rail psi still hit 24k, turbo is really slow to spool(lack of fuel, my guess), no code.
new filters on the air dog and main filter(after the issue) with no change. plugge in the tuner, no change..
Only recent issues is dead alternator.. thats been changed with new batteries as well.(last week)
Any ideas?
Thinking about getting a tech 2 so I can actually see whats going on..
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
Boost leak or exhaust leak??
With a boost leak, wouldnt it smoke a ton? It smokes when it runs good..
so with un-used boost, I would think fuel would just be wasted and blown out the back?
Unless the factory computer is reducing the amount of fuel due to a bad sensor?
I will pressure check the tubing and intercooler today.. but i think its something else, as it wakes up about 2500 rpm and 20 psi..
Anyone?
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
doesn't the MAP not seeing the boost scale the fuel back?
The MAF can limit fuel if it's not seeing enough airflow... but it's pre-leak, so it should still see airflow before it escapes out through a leak.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
Well mine with a boost leak wasn't excessively smoking in fact it was just a grey haze, with the intercooler boot intact it rolls some serious coal??? What could cause that? I was just guessing and it seemed to make sense in my head LOL :D
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
were you getting chitty milage too? MIne has sucked for 2 tanks..
(Like 12)
Your symtoms sound like mine.. I will look for a leak today..
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
No boost leaks between turbo and engine inlet..
wastegate seems to be moving freely...
ficm possibly?
anyone have a deal on tech 2's??:(
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Maricopa, if you'd like, email me any logs you have of this condition and the tune you are running currently and I'll see if you are limping it or something is cutting your fuel. Reach me at: 'sschmitzer' at gmail.com
