02 ccsb 4x4 lb7 only mods is pretty much the ppe xcelerator. Truck will run fine and shift smooth then out of nowhere not even driving it hard get stuck in 3rd gear, will not shift down from 3rd or up. The shift indicator doesn't blink or anything, reverse still works. Usually when it does it I can just reset the trans with the ppe then get back to Rollin and it does fine, today going to work when I started the truck it was stuck in third, and I tried resetting the trans, and put it back to stock tuning, and still stuck in 3rd, cycled key on and off several times and still stuck so I drove to work doing 30mph then when I left work it shifted through every gear fine. What is this??
